Difference between 736 and 738
Car  FF Clio 182
May have been covered before but I couldn't find an exact answer.
From what I have worked out they use the same block just have different inlets? So if I had a 736 engine it would go in a 182 if I used all my original parts off the old 738? Is that correct.
Just you see just the block advertised by 736 or 738 so wasn't sure if they was different.
From what I can tell its only the decanter and rear mounting of the inlet manifold which is different.
On my engine I have noticed there is an egg shape hole on the bottom of the inlet but on the rocker cover its looks like a hole should be there but it's just a flat plate. So the rocker cover breather is blanked off basically.
well you can, but it's a bit pointless buying carbon canister vac pipes IMO, when a bung will do
