difference between -r and +r
Car  172 cup
Could anyone explain the difference between -r and +r on cd and dvd discs?
Apart from compatability issues on certain readers.
Stole from here
http://www.webopedia.com/DidYouKnow/Hardware_Software/2003/DVDFormatsExplained.asp
DVD+R and DVD+RW
DVD+R and DVD+RW formats are supported by Philips, Sony, Hewlett-Packard, Dell, Ricoh, Yamaha and others.
DVD+R is a recordable DVD format similar to CD-R. A DVD+R can record data only once and then the data becomes permanent on the disc. The disc can not be recorded onto a second time.
DVD+RW is a re-recordable format similar to CD-RW. The data on a DVD+RW disc can be erased and recorded over numerous times without damaging the medium.
Note: DVDs that have been made using a +R/+RW device can be read by most commercial DVD-ROM play
DVD-R, DVD-RW and DVD-RAM
These formats are supported by Panasonic, Toshiba, Apple [COLOR=blue ! important][COLOR=blue ! important]Computer[/COLOR][/COLOR], Hitachi, NEC, Pioneer, Samsung and Sharp. These formats are also supported by the DVD Forum. ​
DVD-R is a recordable DVD format similar to CD-R and DVD+R. A DVD-R can record data only once and then the data becomes permanent on the disc. The disc cannot be recorded onto a second time. There also are two additional standards for DVD-R disks: DVD-RG for general use, and DVD-RA for authoring, which is used for mastering DVD video or data and is not typically available to the general public.
DVD-RW is a re-recordable format similar to CD-RW or DVD+RW. The data on a DVD-RW disc can be erased and recorded over numerous times without damaging the medium. DVDs created by a -R/-RW device can be read by most commercial DVD-ROM players.
DVD-RAM discs can be recorded and erased repeatedly but are compatible only with devices manufactured by the companies that support the DVD-RAM format. DVD-RAM discs are typically housed in cartridges.
DVD-ROM
DVD-ROM
was the first DVD standard to hit the market and is a read-only format. The video or game content is burned onto the DVD once and the DVD will run on any DVD-ROM-equipped device. DVD-ROMs are similar to CDs.
DVD+R DL and DVD-R DL
Dual layer technology is supported by a range of manufacturers including Dell, HP, Verbatim, Philips, Sony, Yamaha and others. As the name suggests, dual layer technology provides two individual recordable layers on a single-sided DVD disc. Dual Layer is more commonly called Double Layer in the consumer market, and can be seen written as DVD+R DL or DVD-R DL.
DVD+R DL (also called DVD+R9) is a Dual Layer writeable DVD+R.
DVD-R DL (also called DVD-R9) is a Dual Layer writeable DVD-R. The dual layered discs can hold 7.95GB
The dual layered discs (DVD+R9 and DVD-R9) can hold 7.95GB and double sided dual layer (called dvd-18) can hold 15.9GB.
