disable seat belt bleeper
  BMW X5, Exige 260.
is it possible to silence the annoying warning bleeper on the clio when not wearing the belt?
...and please dont say belt up !!!!! I hate wearing belts when cruising round car parks and the like looking for spaces....the bleeper drives you nuts though.
thanks Adrian
well, and this is the daft answer, you could go around in reverse cause it doesnt come on then! the sensible answer, there must be a connector or something in the seatbelt that you could remove/do something to otherwise it wouldnt know when it was in, unless its all electronic so when the belts in it makes a circuit
  Clio Williams 1, 182,197
Go to a scrappy and by a seat belt buckle !! Then just plug that in when you dont wanna wear a selt belt !!
I dont think you can disconnect it without disabling the seat belt pre- tensioners.
  320d M Sport
newer models bleep until u click it in. if u leave it for a minute or so it will go off and just lights up instead.
so whats a newer model mine dont beep (52 reg) however the 52 reg courtisy car i had did
that was an expresssion could that have anything to do with it?
