Trophy #267
ok lots of current discussion regarding Ik and decats atm and am sortof considering both (prob itg panel for now).
Thing is with decat, whats the overall crack ? Am guessing removal reduces pressure on the exhaust which produces positive results for the effeciency of the engine (ableit with a frown from the environment agency)
So is it just a case of matching the inner diameter of both inlet and outlet (im assuming theyre the same ?) & matching the flanges (ditto).
I say this as im considering getting a m8 to play and weld me one up. Looking at asking dealer if i can keep my faulty one im getting replaced under warranty and matching its length, etc.
Only question is if the 2nd sensor needs a place to be house or if it should be taped up and secured out of system as it woill always show out of spec readings with no cat
to be used with group n ecu btw (aka pikey project #1)
