DIY key reprogramming.. if anyone wants to give it try
Car  02' PH1 172
http://www.programyourkeys.com/Renault_Clio_II_Key_Remote_Control_Fob_Transponder_Programming.html
[FONT=Arial, Sans-Serif]Renault Clio II[/FONT] Key Remote Control Programming
CLIO II INFRA RED RESYNCHRONISING
1. Turn the Ignition OFF.
2. Press the central door locking button for more than 5 seconds. Note: the door should lock then unlock.
3. When this happens, 10 seconds is allowed and the immobiliser warning light illuminates.
4. Point the 1st key at the receiver and press the button twice, the doors should lock and unlock. Repeat for other remotes as required.
5. Check the remote control unlocks and locks the doors.
CLIO II RF RESYNCHRONISING
1. Turn Ignition OFF.
4. Press the remote control once, the doors should lock and unlock.
5. Repeat for second remote if required.
6. Check the remote control unlocks and locks the doors.
Thats the one...
http://wiki.answers.com/Q/How_do_you_reprogram_a_key_fob_for_a_Renault_Clio
How do you reprogram a key for for a renault clio
Answer
to reset the FOB you get in the car, shut the doors. Then hold the cetral locking lock all button down until the doors lock and unlock. The imobilser light goes solid red. At this point you have 10 seconds to click the new unprogrammed FOB. the doors will unlock and lock. Job done
dunno if they work, they might tho, and then you will save a fair share of cash :)
Just tried it with both new and old key. Does NOT work. Doesnt even give a solid light etc... Failed post but good try.
