Got the common speedo sensor fault with the speedo intermitently dropping to zero when moving on occasion, also seem to have a running fault only noticed today
it feels like the car is jerking a little almost like poor fuel or the timing is being advanced/retarded.
Im a bit green with the clio to be honest and only just got it.
I noticed the fuel type is 98ron recomended, it was really low on fuel when I bought it and stuck £10 worth of normal 95 in to get me home etc would that effect the ecu timing so noticeably? or is the speedo fault likely to effect the ecu signal?
Also seem to have a noise from cold from the belt area which seems to go when warmed up. I have checked the belt and tensioner which appear to be fine so maybe, I have a noisy idler or pulley somewhere
got the feeling im going to be pulling it apart soon for further investigation
any likely noisy canditiates? most noise seems to be lower down near the crank pulley.
