Does willy use same wiring loom as 16v
  Trophy
You really need to use the loom that was originally fitted to the car as i found out recently, the wiring to the plugs in the relay box are in different places and i was left without a fuel pump but oil pressure when the engine wasnt even running. then had to swap the looms on the engine while still fitted to the car.
Mat.
  Trophy
Although,
Saying that, i have had a Willy engine go straight into a 16v and work fine off the willy loom?!?
Best off checking the two plugs in the relay box.
Mat.
