can they not be burned out or cut out?You need a press.
Most garages will be able to do it for £10 or £15.
No, they're a different design to the ph2 alright, they're the same as the mk1 clios, like this..http://www.k-tecracing.com/show_product.asp?id=2517if you have/know someone with a bench mounted vice, that'd do it (using a suitable press, obviously - piece of exhaust pipe, etc). or you could probably hammer it out if you were careful and supported the surrounding alloy on a flat surface
ed. if the bushes are the same design as the Ph2's, they're bonded to a steel outer - which is what you're trying to remove from the alloy arm
