Door Handles and bump strips
  PH1 172
Little bit of knowledge needed please :)
Do the bump strips just slide to one side and then pull off or do I need to take the door panel off to get to any clips behind?
How do the door handles come off?
  Fabia VRS
with the door handles mate all you need to do is unscrew the 4 screws at the bottom of the door, then undo the screw that holds in the door handle n just pop it out, then unscrew the one that nect to the window controll (should be a little plastic cover over it and u can just pop that off) then just run a screw driver round the door (u will here a big click [clip that holds it in place] then just run it all the way round) then pull it off.
Hope that helps.
