Megane 225+
My factory door speakers have finally given up - ripped & flapping about.
I'm looking to replace this weekend but need some friendly advice
I have a Pioneer 4 x 50W head unit from which I already run a pair of 6x9's on the parcel shelf & an amp with removeable 10" sub. I will not be running the door speakers via an amp.
But I'm not up to scratch on ICE
so
Budget - cheap so £50 max ish
Do I have to replace with 5 1/4" component speakers or can I replace with 5 1/4" 2-way or 3-way spec?
I've also read that I could possibly run 6 1/2" units (2way, 3way question again)with some spacers which I could easily laser cut in work from acrylic(is depth an issue?) - is this practical/worth the effort? as I will still want to retain my standard door grills
Also whats the minimum spec I should go for?
cheers
so
cheers
