Door swap?
Edd
Car  Ghibli/Boxster/197T
How hard is it to swap a door on a 172? And would a ph1 door fit a ph2 if I swapped over bumpstrips??
easy mate undo check strap and unplug wires from door kinds plugs into 1 pillar and then unbolt the hinges and lift of . and yeh it would mate there the same car just diff rear lights and wings bumpers thats all .
Cheers mate, so even though its a different wing the door would still line up?
yeah should do, just make sure if you go for a ph1 door get a door from an X plate clio or later. the holes in the door for the bump strip are diffrent if you get a door from a previous year and its a hole load of hassle
