Downstream lambda
Car  '92 172, Lotus Elise
Am I right in thinking the downstream lambda is only required to test if the cat is working correctly? It has no bearing on fueling or anything else?
(on a ph1 172)
phase 1 should only have 1 sensor. Pre-cat.
Maybe some very late 'Y' plate cars would of had them, depends which loom you have. But yes you are correct
