Dreaded Misfire!!!
Car  Clio 172 ph1
So the problem started after I removed and refitted my injectors and top inlet. Took the car out and was fine for 10 minutes, then developed a bad misfire. This is mainly when warm and under load.
On investigating I pulled the lead off the injectors, pulling the leads off one injector made no difference while the others made it run worse. So I fitted a new injector, but hasn't helped.
So now I am thinking leads, coil or plug. But am I right in focusing just in this cylinder due to the above?
Injectors are reading around 16ohms, where the old one was 14ohms.
No codes, but still running bad. Thinking leads or something now
Pull the plugs and give them a clean.
When rebuilding ensure HT leads are are fully seated on plugs and be careful not to trap HT leads with top manifold
New injector, leads and plugs in the end. Annoying as its happened in some way to all 3 clios I've owned.
If I ever own a 4th I think I will budget to change the injectors straight after I buy it!!
