Drivers Door Removal Anyone?!
Car  Renault Clio 172 Sport
All,
Im just in the middle of replacing my gfriends door on her 172 (02). got everything off apart from the damn window winder motor. I have no idea how to get the motor arm off the window, nor the window out of the door?! Im presuming once the window motor is off the window will slip out. Can anyone explain or point me to a thread that shows how to remove the window winder motor? Thanks
there is a little white clip on the bottom of the window... pull this out and then lift the window up and tilt it slighty and just pull it...because there is a little clip on the back of window that needs pulling out of the seal...!
Once you got the window out the motor just needs unbolting and pulling out!
Cheers Clio1990, all sorted... although i broke the clip! lol. Looks like a couple of quid from Renault!.
