Drivers front fog light not working
Car  RB Clio 182
Hi, i noticed my drivers front fog light wasnt working so ive just changed the bulb and it still wont light, ive cleaned it with electric cleaner and the pins are straight and the wires look good.
Do both front fogs run the same fuse? All my other lights inside and out work apart from the front drivers fog light.
Any ideas please?
Check the contacts at the plug on the passenger side behind the bumper. I'm sure both lights are fed from the same plug.
The passenger light is working, could this effect the drivers side only?
Cheers mate.
the plug is behind the passenger side and contain connections for both lights i think. Im sure when i removed my bumper there was only the 1 connector block needed unplugging.
Cheers mate, ill clean these connections and see if it helps :)
