Drivers side wiper not working (stuck on m1!)
Car  Imp Blue Mk5 ZS
Drivers side wiper not working (The Boosh! stuck on m1!)
Luke (The Boosh!) has just rang me, hes stuck on the m1 with only the passenger side wiper working. What can he check?
Thanks!
Come on homos. Dunno what i can check? Managed to stumble off m1 with one wiper. Still stuck tho? :(
Right. Drove back leaning over...
Could anyone advise on how to take off the scuttle panel as I cannot work it out?
I think the linkage has fell off or something?
either linkage fell of or broke, i've had same £35 for second hand mechanism . . . make sure you get the rite one though (plugs differ)
Rubber off scuttle, remove wiper arms, unscrew any screws on scuttle, lift and pull towards front bumper
Remove the wipers.. could be a pain! Mine are/was... Under the bonnet on either side in the corners there is a bolt iirc, undo those, scuttle should just lift out the way sliding towards the front, starting with the offside piece first..
Edit: Pipped the post!
Linkages probably popped off mate. Have a look at the scuttle its pretty easy to work out how to get off, first off though have you opened the flaps, and put your hand in see if you can feel the linkage connected etc?
No not done that mate... Don't quiet know what you mean :o
Thank you for your advice people. I will start taking it off now... :(
Pop the bonnet and there's some flaps, actually coming to think of it do they have them on a mk2? Do on a mk1 anyway....
