Right. If you look at the picture above, this is the megane seatbelt.
On the megane, im assuming that there was a bolt which screwed into the tapped hole and went into the chassis. On the clio. This is not the same.
There is a bit of metal, around 10cm long which bolts into the chassis further down and then the other end of it is onto the seat belt mechanism.
So i undid this and where it connected to the seatbelt mechanism on the clio was a big old school rivet.
I got a 6MM drill bit and drilled the old rivet out so i could get this piece of metal.
I then got some 10MM hign tensile rivets and dug out my rivet gun. (It needed some WD40. HAA)
I got a 10MM drill bit and drilled the tapped bits out of the megane mechanism so it was nice and smooth, then i placed both bits of metal together and wacked the rivet in. Then just put the bolt back in the bottom of the bracket and put this into the clio chassis.
The Finished Item
Well, overall im really happy with the seatbelts. I need to clean them up a bit more.. (Anyone know what i can use to get a good clean finish ??)
Heres the pictures.
Well. Im BUZZING i finally got them in. I hope you guys like.
Any questions fire them over!
Thanks, Sam!!
