collecting my 1.2 16v dynamique at the weekend, what is the best route to go down in regards to handling? i was thinking leave standard 15"s and lower 40mm or upgrade to 16" 172 alloys and lower it, what does anyone recommend?
i wanted to keep costs low hence the reason to go just for springs, either apex -40mm or pi -60, i thought the -60 would be a bit much using standard shocks.
ive had both Apex 40mm springs and im now running Pi 60mm springs (standard shocks) I would say ride and handling is better on the 40mm springs than the 60mms. The handling on 60mm is a bit bumpy and the car can hop around a bit. Im eventually going to upgrade to koni adjustable shocks or full on H&R or K&W coilovers
ive got -35mm Pi springs on standard dampers and wheels, give a good ride but seem a bit soft, 2hotty - you say that you can fit 17s on with no mods, what style did you go for?
