ecu virginise / immobiliser issue
  ph 2 172
ok guys new member with a problem. immobiliser is intermittently not switching off when i go to start the car. key was in a poor state when i got it so this may be the issue. however to solve problems i figure i will get the immobiliser taken off the car. does anyone know of anyone in the teesside areawho can remove the standard immobiliser from a phase 2 172? alternatively a mail order company who can do the work?. or even any different suggestions? cheers.
btw this is a real pain when it takes upto 4 hours for the car to recognise your key.:evil:
  ph 2 172
update: renault want £130 for a new key. this includes programming it to the car. anyone know if this should work?
  Astra 1.9Cdti SRi
You cant remove the immob from a ph2 172, people have tried and cant, just to clear that up
  ph 2 172
I was under the impression that ecu could be virginised and an emulator fitted to overcome the ecu? Or is that ph 1 only?
  LY 220 Trophy+IB PH1
I have the same issue with mine, sometimes it wont start and sometimes you walk away and press the central locking button only to have to return to your car with an embarrassed expression on your face as you have to go back to the car and fiddle with the key to get it to lock :/
Other than changing the fob/key blade there ain't alot else I could suggest.
  MG ZR x2, Polo, CTR
Mine has this issue and refuses to work full stop :S
Although I fixed a 1.4 with this problem yesterday, happened to be a duff fuse, odd, but there ya go
  ph 2 172
check the battery holder within the key. the soldered joints on myne were broken but a little soldering and job done
