Eibach camber bolts kit
  Renault clio
friends.
I want to give my little clio sedan camber with (Eibach camber bolts).
Besides changing the bolts have to change anything else?
What other recommendation I can make?
Will you bring any result with these bolts give camber?
Damage something? Could if I put these bolts?
regards
  mk1 Octavia VRS
Why do you want to change the camber from stock?
You will need to get the camber and tracking adjusted after fitting the bolts because you want the camber to be the same on both sides and changing the camber will change the toe, so the camber must be set first and then the toe.
