Eibach camber bolts
  clio 172 phase 2
Thinking of buying a set of these for my coilies what would be the nest camber set up for fast road . Anyone had an experiences with them?
  172/1.2/E30
I am running -1°30" (-1.5 deg) and it's pretty good. Don't your coilovers have elongated holes for camber adjustment?
  172/1.2/E30
Don't know. You could remove the upper bolt from the strut-hub connection and look if it is a regular hole or elongated.
Nickson
Neither set of GAZ coilovers for the Clio come with elongated top holes for camber adjustment, so the bolts must be used.
I had to use them when I ran my old GAZ GHA's.
Probably best just taking the car to your local motorsport garage and letting them do the work.
Sir_Dave
ClioSport Trader
Any idea's on how easy these are to adjust, on the Trophy i just maxxed them out & they are running -2.8 degrees, now i want -1.75.
Is that like 'half a turn' less or do i need to pay someone to set them up for me ....
  182 cup
They are easy to adjust, slacken of the nut, twist bolt to the desired direction, but you'll need a gauge to know where you are.
You can get a cheap camber gauge from the likes of e-bay and set them up yourself, just remember that changing camber will also affect your toe-in/out so you'll need to do that as well. Again with the right kit you can do it yourself (I do) but if you've got somebedy nearby that they can set it for a reasonable fee, then that is probably the easiest option.
