I have had problems with my 55 plate clio 1.2l 16v since buying it pretty much, with the engine management light and the electronic fault light constantly being lit up and I've had enough.(great little car too apart from the endless faults!)
I had a mess around with it for a couple of hours yesterday and seem to have got rid of the engine management light, went a drive last night for an hour or 2 and no lights atall, until today when I had to go out and the stupid little electronic fault light appeared yet again. (I cleaned the throttle body yesterday along with some other things, reprogrammed it?, left it to warm up and it drove perfectly for the full time I was driving it)
When the light was still on tonight (before I cleared it with engine restart) I plugged my code reader in and the code was PO638 - throttle actuator control range/performance bank 1 (I've had this fault code before but it was when the engine management light was on, not the electronic fault light) and someone said it was a throttle body issue then? BUT, I have noticed that the light seems to appear mostly/more often when slowing down e.g. removing foot from the throttle to use the brake pedal, using clutch to change gear (sometimes), putting the foot down (sometimes) if I go over any big bumps and when my petrol tank reaches 1 bar/gallon it seems to do it alot more, my temp. doesn't seem right. Are these just coincidence?
What I'd like advice with is:
1. Is it worth just saving up and buying this new throttle body from ECP http://www.eurocarparts.com/ecp/c/R...08902e84675629a39a3859838c49382dd88d0d&000329 (I have read somewhere of people buying a new one after getting this code then the code re-appears)
2. Should I try and get a second hand one if the seller can be trusted and it definately works?
3. Should I just put up with it until I'm working again (risking death on motorways and dual carriageways) then buy a better car and send the little french fault box to the scrappy/break it/ torch it?
4. Is there anything I can try in order to fix it? I have a full day of doing nothing tomorrow so I could mess around with it if I feel like it.
5. Can limp home mode be disabled somehow? I'd be happy enough if that was possible tbh
Sorry for all the reading! I wanted to give as much info I could think of incase it helps
If someone could give me any advice/help/maybe a throttle body to test out and confirm mines is faulty it will be appreciated, I love my wee car but I've had enough now and its going to drive me mental soon.
