electrical problem
Car  182 trophy
My 172 cup has been sat doing nothing in the garage for the past 9 months. Trying to get it back on the road now but when its running it has on the battery and stop light. Iv put a new battery in the car but this is still happening, is it likely to be the alternator that's bringing up these warning lights?
Was it off the road for any specific reason that might actually be relative to your issue?
Have you had the new injectors paired to the ecu
That only applies to diesels mate.
Your symbols mean the battery isn't getting a charge. Check that there's not been a rust build up on the alternator connector and if you have a multi meter find out what voltage is a going across the battery when it's running. If its not a poor connection then it's a new alt that you need.
Cheers mate, I will have a look again tonight.
