Electrical problems, Hazards, Windows, Radio Diming
  172
Hi all,
I've been having a few electrical problems with the electrics in my 172 and I wondered if anyone knows how to fix them!
Hazard Lights Flash when Driverside window reaches max height.
This is an odd one, when I raise the driverside window to the top the hazard lights flash once. This only happens if I keep my finger on the switch and not if I use the 'soft close' feature.
I have found a few threads that describe this problem but no fixes:
http://www.cliosport.net/forum/showthread.php?377145-Drivers-side-window
http://www.cliosport.net/forum/showthread.php?501832-Window-switches-and-hazrd-lights
http://www.cliosport.net/forum/show...about-clio-s&p=3731190&viewfull=1#post3731190
http://www.cliosport.net/forum/showthread.php?536454-strange-electric-fault-annoyance
http://www.cliosport.net/forum/show...-do-you-have&p=7187505&viewfull=1#post7187505
http://www.cliosport.net/forum/showthread.php?75153-electric-windows
Radio Backlight Dims when Braking
Another strange one, when I brake the radio backlight dims (like it does when you switch the lights on at night).
Radio Backlight flashes with Indicator
This one I haven't noticed happening as often but sometimes when I indicate the radio backlight gets brighter/dimmer in time with the indicators flashing! This maybe just happens when the lights are on at night.
I have lived with all these problems for a while but I thought it is time to do something about it.
Any ideas?
Thanks,
Paul.
  1.2 16v clio
this is a drop in voltage causing the lights to dim
my car used to do this but i upgraded the wiring for the alternator and added more batteries since i run audio
you can upgrade your battery to a higher ah/cca also the wiring for the alternator can be upgraded so the alternator can get the most out of it as possible
