Eltronics help needed
Car  Clio 1.4 16v
To put lower voltage LED's into the 12 volt power of me car, what resistor will I need, thanks
Here's the famous pyramid....
V
I R
V = IR
I = V/R
R = V/I
You need to use the bottom equation. Your LED will have a current rating, most are around 20ma, but will depend on brightness & colour.
R = 12/0.02 = 600 Ohms
And the other thing to make note of:
P = VI (Power in watts)
P = 12*0.02 = 0.24W
So you need your resistor to be at least 1/4 of a watt rated.
Just replace 0.02 (20ma) with the rating of your led in the above equations and you should be good to go.
OK, probably a silly question, but can I find the current rating with a multimeter?
No. It'll have been specified either in the catalogue or on the packaging (if you bought from tandy or such like).
i've used this before to find out what resistors to use
yeah it's all about current when it comes to led's
too complicated, lol
I like the simplicity of the other one, just gotta hope its right and all my LED's don't blow :)
