Emissions light and slightly low MPG - Pre or post cat lambda?
  Looking for 182
Hi all,
For the past couple of months I've had slightly lower than normal MPG, at the end of a tank it's usually around 32MPG, whereas normally it'd be about 34 or so. Nothing major, and I've just put it down to being winter really.
Last week I had some work done to mod the cat to a 2.5" exit with a straight through pipe (centre silencer removed) to my Milltek back boxes. All is good, except last night the emissions light came on. Now, the cat is still in place so I don't believe this should be happening.
Based on the above, do you think I need to replace one/both of the lambda sensors? I have no other symptoms, and the car is driving brilliantly.
