Andyano12
								172 cup + more
				Hello everyone,
I have looked through the previous threads but have been unable to find something which completely matches my symptoms..
Car has been running fine and being used everyday.
Noticed a few days ago that it was slightly hesitant on about very light throttle, any more it would be fine and pull as per usual, this seems to be getting slightly worse the past day-it had been raining-now sure that would have affected it. Starts fine and pulls well, there are no warning lights on the dash at all.
So I had some OEM injectors which I bought a while ago and have changed these, to no effect. My next thought would be coil pack and/or the lambda sensor, I believe the lambda can be swapped pre and post cat so may try that. But before I start doing all that has anyone else experienced this and what did you do to rectify.
Thanking you in anticipation.
