Hi,
As some of you may know I bought my 182 needing an engine. Now that the car is on the road again we decided to lift the head off the original engine to see if we could find the cause of failure.
Failure is in cylinder 2.
The spark plug threads are not good from the plug being struck (gap was totally closed and visible marks on it)
Engine ran on 3 cylinders, no bottom end noises at all, infact I had it at 7200 rev limit to check if the gearbox was fine before pulling the whole lot out.
Anyway onto the pics,
What’s your thoughts? Valve seats are still there, none of the valves have dropped. Only two of the 4 valves are visibly bent. No scoring on the cylinder walls so I’m assuming it wasn’t a ring failure.
Will remove the rod and piston at some stage this week hopefully.
Cheers,
Rick
Cheers,
Rick
