CLIO-Si
1.6Si + 182
can anyone tell me which mount has caused my engine to fall into the inner drivers arch?
ie. what way does the engine drop when the dogbone or the top drivers mount goes?
also anyone know how far away the inner arch side is from the aux/timing belt?
im going to go and check the methods for the drivers mount and dogbone mount adjustment but would like a guide on how the engine should line up with the arch at the side and also how the sump lines up with the bottom subframe/member.
