Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
There's two on the gearbox. One's a greenish coloured earth strap that bolts from the body to the lower gearbox mount. Another comes off the engine loom and bolts to the gearbox housing at the top/back of the box...
So just hook my 0 gauge onto where the greenish wires connects?
And i have to disagree because i've already upgraded my battery ground so my battery to accessories is running off 0 gauge, if i didn't upgrade my engine ground and alternator positive in theory i would be pulling more current from my battery than then alternator could put in.
but the alt outputs power down the positive and the ground is there as a reference and the current from your install goes through the chassis to the battery
so upgrade to alt positive so you lose as little as possible but i don't see the point in the engine ground
You can clearly see where the weakest link is in the charging circuit.
The reason i am upgrading the charging circuits wiring is because i don't want to be drawing current from my battery that the alternator cant replace. And when your engine is running your alternator is supplying power to your accessories AND charging your battery, so if anything your charging circuit should be able to provide more current flow than your accessory circuit.
