A few
Before posting, i have done a search on this and could not find the problem that i have.
When i start the car it is fine but if i go slow in 1st gear the car will start revving and then the car will cut out unless i rev the car. The engine management light will flicker when this problem occurs but will just go back out after.
The problem does not occur all the time, but it is getting annoying.
Does anyone have any advice on what the problem could be? I have had it connected to a code reader but the code reader can only read the problem if the car as the Engine management light on.
