Ph1 track 172
Car will be fine for,
then all of a sudden it will feel very limp and then the back back to normal a second later.
If it happens in first or second gear, you go kangarooing (SP) off down the road,
basically it seems the engine is not firing on either one or two cylinders for a few seconds,
but then the problem disappears,
its happened while sitting in traffic (idle just drops and car shudders)
while pulling away, and while accelerating though 3rd gear (50-60)
any ideas what it could be??
ive changed the plugs for some nice bosh ones,
took the distributor off and cleaned it up,
cleaned up the HT leads,
then took her out for a rather hard drive,
initially the problem came back once or twice,
but then it seemed to go away for good......................for now,
but what else should i be looking at??
coil??
its an F7R engine btw
coil??
