Engine Missing - Need help
  Clio Sport 172
Just got in my car to go fill it up with petrol 4 work 2mo turned it over and its missin like a good 1, pulling then shutting off and wont rev over 5000rpm, was fine when i parked it up earlier, has had a little flat spot between tickover and 1500rpm but that was there when I had it, any ideas guys
I thought poss plugs/coil pack but i just realised i did wash the engine down with degreaser Sat and havent really used the car since, could possibly be some moisture on the plugs/leads etc
How do you get 2 the plugs on these things is it a case of having to take the inlet manifold off, soz 2 be a nuisance but iv only had the car a few days so still finding my way around it atm
Popped the inlet off earlier guys pulled the leads out there was loads of moisture on them. wiped them dry and sprayed some WD40 inside them before putting bk together and car is pulling smoothly through the rev range now.
Still sounds a bit lumpy on tickover no missin etc though, is this jut normal on these cars???
Hi Guys,
Car has started missing again this morning, it seems fine when cold then starts missing approx 20-30 mins into a journey, could this more than likely be the coil pack
