Doesn't happen very often this and it only happens when the engine is cold.
On idle not long after starting the car seems to miss for a second, seems like it runing on 3 cylinders and nearly cuts out, a second after the car picks up again and runs fine. It'll only do it on the very rare occassion but just curious to what might be causing it.
The obvious things would be Plugs, Leads, coil pack etc.
