Hi,
Its not a sport but worth a try.
My sister has a 1.2 16v dynamic, and recently it wont start for a while after it has switched off. so she was getting petrol the other day, filled up went to start the car again and nothing. left it for a while until I got down there to help her. turn it over first time and worked. happened quite a few times since.
I started this thread originally because someone at work said he had the same problem with his Clio called the AA out and the AA guy cleaned something and it worked fine after. my friend don't know a lot about cars and said it was something next the the starter motor that is magnet and attracts a lot of unwanted stuff.
Wound any one know what this is called so I could give it a try.
Or if you know what else might be the problem I am willing to listen and try.
Thanks in advance.
Thanks in advance.
