Engine not starting stright away
Hi,
Its not a sport but worth a try.
My sister has a 1.2 16v dynamic, and recently it wont start for a while after it has switched off. so she was getting petrol the other day, filled up went to start the car again and nothing. left it for a while until I got down there to help her. turn it over first time and worked. happened quite a few times since.
I started this thread originally because someone at work said he had the same problem with his Clio called the AA out and the AA guy cleaned something and it worked fine after. my friend don't know a lot about cars and said it was something next the the starter motor that is magnet and attracts a lot of unwanted stuff.
Wound any one know what this is called so I could give it a try.
Or if you know what else might be the problem I am willing to listen and try.
Thanks in advance.
yeh when you buy a new one you have to buy a new plug with a loom on it aswell, well on the 172s you do im not sure if this would be the case for the 1.2s or not. its a modified plug i think you just cut off the old one and solder on the new. renault parts will be able to tell you for sure, does sound like the tdc sensor too me.
