Clio 3 2010 1,2
My Clio 1,2 D4F from 2010 had a cam belt that snapped. The valves/pistons are OK with compression of 13,5 to 14,0 bars after the repair. I replaced the belt and I am confident that I got the timing right. I got all the markings right at least. Now the engine doesnt run as it is supposed to. It starts fine and the sound of the engine is great at low idle. If I push the throttle like 1 mm the engine revs up fine, but if I push the throttle like 2 mm or more the engine just dies. By being carefull I can get the car up and running to about 100kmh but it is VERY weak (I can´t push the throttle more than one mm). I have NO alarm sysmbols on the dash - it all looks normal. I have rechecked the cam belt position. I have replaced the throttle house, ignition coil, spark plugs, cleaned the crank sensor. There are no leakages in the vaccum system.
Am I missing something, is the engine in Limp Home Mode even if there are no alarm symbols on the dash?
Please help me with advice.
