Engine Sump Tool
  E92 330
hi, jus a quickie. what tool do i need to undo the plug at the bottom of the sump and where do i get it?
clio dci 1.5
cheers rob
  Mazda MX5 1.8
i bought a tool from halfords (made for the job)
think its just called a sump plug adaptor xxx size (worth getting the tape measure out to make sure u get the right size)
8mm for my 1.6 - dunno if the dci's are the same
  mk4 golf gttdi180
halfords should have one if not try sockets or a chissel and hammer and just give it a tap and then put a wide enough straight screw driver in
  BMW M135i
As said it should be an 8mm square sump plug key. Buy one for the sake of a few quid, using chisels and hammers = Pikey Engineering lol.
MRBILLYUK
  FF Jeden Osiem Dwa
Hammer and chisel :nono: I'd hate to think what you use to change your spark plugs :banghead:
