Hi guys hoping one of you lot might have an idea...
My 182 has currently got a misfire when on closed loop and has been diagnosed to be the upstream lambada. But it's also got a fairly loud tapping noise from the head area (kinda like spark knock) so i took the plugs out and noticed the pistons are excessively carbonised just wondering if it is A: likely to be the cause and B: best way to clean it off without taking the head off.
The car has 79k on it and oil change just done also tried changing HT leads and plugs. I've kinda run out of ideas now without taking the head off to see so getting rather fed up with it
Thanks in advance
Thanks in advance
