engine upgrades on a v6
apart from full zhorst and airfilter
what else can u do to push these towards the 300 mark, without nos i mean
would a chip do a lot (ecu) what would u gain?
[Edited by loopee on 05 August 2005 at 7:00pm]
Headwork, Phase 2 manifold with modifications, cams, management, increase in CR.
3.2 or 3.5ltr conversions.
Throttle bodies
Supercharging, screw type, not centrifugal would be my choice.
lots and lots and lots, BUT!!!....it will always cost a fortune due to the nature of the car.
on this engine, not much...bolt ons only go so far as exhaust and filters.
You can modify the inlet manifold to work better, which does give surprising gains, but even the remap is costly.
What sort of budget are you working to?
  Forester Sti, SC Clio V6,
Were into the ECU so a remap for decent fuel and some more advance is on the cards without spending a fortune - still go filter and plenum/throttlebody though.
In fact filter/TB/plenum/remap should be less than a grand
Just about ready to dyno my new engine, spec; Omega hc race pistons, polished and peened rods and crank, ported and gas flowed heads, gas flowed plenum, Newman wide lobe cams, grey injectors, race coils, full balance, Motec 800 ECU with launch control, etc, janspeed manifolds and connectors with lightweight silencer. Will post dyno test print-out when we get it.
Depends what youre planning to use the car for anyway. Expect prices to drop over the next few years as more tuners get involved. But these engines were built tight and perfomance increases after about 6K running-in. Also they like good fuel.
Quote: Originally posted by hog1 on 06 August 2005
Just about ready to dyno my new engine, spec; Omega hc race pistons, polished and peened rods and crank, ported and gas flowed heads, gas flowed plenum, Newman wide lobe cams, grey injectors, race coils, full balance, Motec 800 ECU with launch control, etc, janspeed manifolds and connectors with lightweight silencer. Will post dyno test print-out when we get it.Depends what youre planning to use the car for anyway. Expect prices to drop over the next few years as more tuners get involved. But these engines were built tight and perfomance increases after about 6K running-in. Also they like good fuel.
Sounds a stunning spec is this going in a road car? What about transmissions? Any idea where your going to rev limit it?
Road, shopping, pub, club sprints & hillclimbs.
Will have to try the tranny as standard but will see if we can change ratios and fit an lsd when we see the dyno curve / plot. Mike T is still running a std tranny on his blown car I believe.
Rev limit is why I want to dyno the engine and not just drop it in the car. Need to study vibration readings but really looking to hit max torque at 5K and the see what the curve does after that.
  GDI Demo 182, Rsi Spider
we can tune the fueling with the SMT now, we established this..
but you do need a aftermarket exhaust with decat as well.
Andy
  V6 Mk1/Beat/E320/Mcoupe
Andy
Do you need the car in order to install the SMT? I live in Hong Kong and will not be able to bring it to you. But I would like to chip my V6
Andy
What bhp/torque gains were made with the SMT and the decat?
Andy
decat is causing me big problems apparently according to reanult with my warning light and making my car go sluggish that right, k tec rekon i need 2 sports ones in there with the manifolds too , costing a grand???
  Lionel Richie
Quote: Originally posted by Andy GDI on 07 August 2005 we can tune the fueling with the SMT now, we established this..
Andy decat is causing me big problems apparently according to reanult with my warning light and making my car go sluggish that right, k tec rekon i need 2 sports ones in there with the manifolds too , costing a grand???
[/QUOTE]
nope, ring andy 07010716440
