Well column is 2 parts which gives you small angle adjustments, so once the wheels are on if it’s out you only have the column joint to deal with not from the rack or anything.
A lot easier to do this with epas that’s for sure.
I wasnt sure as ive just bolted it in for now. I need to fit the trackrods and front hubs then i will know exactly where it is. Was just curious if there was a specific method as ive nevere messed with steering racks
