ESP and SERV light
Car  Clio 172
I swapped the steering angle sensor today as I had the ESP, SERV and ABS lights on. After swapping it the lights went out. I went for a drive and when I turned the wheel the ESP and SERV lights come on. Theres no ABS light and th other 2 go off when I start the car again until I turn the steering wheel again. Is the the SAS needing calibrating or could it be the switch under the brake pedal?
SAS Fault i'm afraid.
It *may* simply need re-calibrating but it may also need replacing if its broken/damaged/duff/incorrectly installed.
MIck
