ESP light is on....
Car  R35 GTR
I have no esp or traction control after the oil leak. Renault havent fixed it yet.
would this be related to the oil that covered my drivers side wheel?
ABS still works.
edde said:
Sounds like they've forgotten to plug the sensors back in or broken them or not set them right.
I had a major oil slick on the drivers side wheel, could this have messed with the sensors?
It's really strange not having the esp kick in all the time, the car actually feels alot different.
yep sensors might need cleaning hey should have (from memory) .5 to 1.5mm gapping between sensor and the wheel pictup but its probably got oil on it won't take long to fix.
might have a go myself, what do i need to look for, I have some brake cleaner in the shed.
Get them to do it.
I'll get pics tomorrow as I've a hub in the garage.
removing the snesor might be a bit of apin you'll end up probably leaving it inplace and spraying something as close as you can and hope its cleaned it.
You might find the sensors just not connected.
edde said:
Get them to do it.
ah ok, I'll leave it for renault if i have to start unbolting things.
