Hi All,
After accelerating hard out of any right hand bend ( although strangely not left hand ) the above warning lights come on and my 172 goes into what I can only presume is limp home mode - the engine revs constantly at around 2K rpm and the throttle seems to be disconnected.
After turning the ignition off and back on everything is back to normal.
I am presuming the warning light directly to the right of the ESP light is a temperature warning light? is this correct as the cars under warranty and I'd like to be accurate when booking it in.
Anyone else had this problem? - Does the ECU keep a list of faults as I'd rather not have one of the tech's racing round bends trying to duplicate the fault!
Ta,
Andrew.
Ta,
Andrew.
