Excel Formula Assistance
Car  Bumder With A Buffer
Im having an extremely blonde day today and just cannot get my head around why this formula is incorrect.
I have made a spreedsheet that tracks TOIL for us here at work but I hit a snag when a MINUS number of hours are added into my cell.
Formula is this in cell Columns I...=SUM(F4-G4+H4)............This cell is formatted with [h]:mm as I need the TOIL to be shown in that way
Cell F4 = Monthly Total of hours formatted [h]:mm
Cell G4 = Hours should be worked that month formatted [h]:mm
H4 is Balance brought forward. Now this last cell is also formatted [h]:mm and works fine until a minus figure needs to go in that. I have to do '-16:30 to get the minus hours in there and then get an error in my calculation #VALUE!
Now I can get the formula to work by changing cells in H and I to GENERAL but then the resulting calculation is displayed as say 16.75 hours which is not how I want it displayed.
Anyone able to shed some light???
Fcuk it I played around and came up with a "solution"
Made an extra column of "hours" that is the negative column. So I have 2 columns for TOIL hours from previous months. One for positive one for negative hours.
Then made a formula that says if its in that column to minus it, if its in the positive then add it ... =IF(H27<>"",J27+H27,J27-I27) Appears to work so all is good and displays in the format hh:mm which is what I want.
That'l do pig
Rich - I think i've understood you correctly...
If you want to do it with out faffing about with extra columns etc, it is possible.
Is the attached what you were looking for?
​View attachment Book1.xls
If so I will talk you through what the crack is.
Do you not have to 'tell' your formula the negative number should be read as an absolute value?
You can stick =abs(formula) in front of the sum that the OP has posted, however it's a bit misleading as not easy to identify who has a positive and who has a negative balance.
Cheers for the post Boosh..
its a bit more complicated then that though.
I have 5 Sheets on the workbook. First 4 are weekly time in and outs split into days.
Important stuff is on last sheet to do with monthly totals. It takes the data from sheet 1 and populates that cell (formatted [h]:mm)
Does this for the 4 weekly totals in columns B, C, D, E
Column F = =SUM(B4:E4)
Column G ="37:30"*4 to give hours should work.
Edit sod that here is a rough example if dropbox works
https://www.dropbox.com/s/th5okhfopeku2fl/TimeSheet.xls?v=0mcns
Only have 1 week on there usually I will have 4 and then the sums mentioned above.
I used to do it by just having one coumn for TOIL "H" and then do this in difference =SUM(F6-G6+H6) but if any negative value was added into column H I would get a #VALUE! error due to having to put a single quotation in that cell to get a negative number.
