Excel Help.
mace¬
  Clio
I wonder if anyone can help me.......
I have an excel spreadsheet In column A I have codes and in column B I have comments. For example:
What I need to do is sort by the code in alphabetical order keeping the comments attached? Problem is the only way we could get the data in was to have the comment info on different rows
Roughly 20,000 rows with 4 thousand codes.
Ta,
  Cupra
- Put an autofilter on the top row.
- Select "only blanks" from column A
- Put the formula =A2 in cell A3, then copy it and paste down the rest of the blanks.
- Sort by Column A, the comments should all stay in the correct order with the Code in alphabetical order.
sbridgey
  disco 4, 182, Meglio
Are the comments all in the same cell technically or have they gone to the next cell once one is full, if u know what I mean?
mace¬
  Clio
You sir are a genius!
One more thing, once sorted into alphabetical anyway of removing the duplicate codes in column A we created?
welshname
As a future note i would format the comment cells so that you only have 1 cell per comment per code. Just format the cell for "text wrapping" this will allow you to make the cell "taller" rather than "wider" and mean sorting them in future will be a lot easier.
mace¬
  Clio
The way we extracted the data from the system didn't allow us to do that. Data is sort of stored on an array and we had no simple way of stringing it together and then extracting it on one line.
Couldn't be assed to write the code to write it directly to a file so it had to be a copy and paste job.
welshname
Fair point. Whats had already been said above is the easiest solution then.
  Megane 225 F1
Seriously mace, apart from teaching me, being awesome and well hung, helping the poor etc...what Is your actual job?
  Cupra
Yes. Before you start, from the top:
- insert a new column infront of A and name it "Temp".
- unselect "blanks" from column B
- You should now only see the Code and the first line of comments. Type "keep" in A2 and paste down to the bottom.
- reSelect "blanks from column B so that all data is visible.
This will add "Keep" next to each "Code" value.
then what I said before (changing A-B as you have inserted an extra column):
Next bit:
- Using the autofilter, only select the blanks from column A
- Delete all the text from Column B
- Turn off the autofilter.
- Delete column A
There must be an easier way, but I always use the autofilter work arounds for stuff as they are fairly quick.
mace¬
  Clio
Penquin picker upper.
Next bit:
- Delete column A
Thank you. Another happy customer.
