172 cup ABS problem
colesy
Car  172 182 197 E61 530D
Now I’ve got you in with my ‘172 cup abs problem’ and you thinking but they don’t have it, mine does as @GrahamS retrofitted it.
So the last few track days I’ve done I’ve had an intermittent ABS light appear, ignition reset sorts it.
But it’s now grown into a bigger problem. On live data I had my right rear sensor reading 195kph at standstill, replaced the sensor now all reading as they should.
But now is my issue, the ABS light still comes on. I have 3 codes stored but as it’s launch tester I’m using predictably they’re not on the database.
The ABS light only comes when you’re moving and goes out when at a standstill.
Obviously in a perfect world I need to get it on Clip.
I was wondering if anyone else has had this issue or similar?
I’m thinking maybe a wiring issue somewhere.
Let me know, cheers
