Excell Help
MatthewR
I'm currently working on a project and part of it is creating a new scoping tool to assist myself and in the future colleagues.
We have a set of data (base rates) which are all on their own sheet, we then have a 'front page' which we have set to pull data from the set rates when numbered.
What I am trying to achieve is that we can input on the front sheet the rooms e.g
Preliminary items
Living room
Bedroom 1
Bathroom
And when these have been input it auto populates new sheets copying the set rates across so that the front page (scope) will then display all the items set across the relevant rooms.
Is this possible? If so how?
  997, e208, I.D. Buzz
You mean you want to lookup the values from 'base rates' sheet, and return them to 'scope'
To do that you need a value to lookup against, call it "Building" (and the building contains the rooms) - Consider using XLOOKUP, depending on your Excel version.
Code:
=XLOOKUP(lookup_value, lookup_array, return_array, [if_not_found], [match_mode], [search_mode])
Code:
=XLOOKUP(G3,Rates!B3:B7,Rates!C3:F7)
Scope
Rates
Alternatively, and more legacy, you can use VLOOKUP for the same
Code:
=VLOOKUP(lookup_value, table_array, column_index_num, [range_lookup])
Code:
=VLOOKUP(G3,Rates!B3:F7,2,FALSE)
If they're tabulated differently, change to a HLOOKUP (works the same, just the axis are reversed)
Or, to work with no indexed data, using INDEX/MATCH as a combo
Code:
=INDEX(Rates!C3:C7,MATCH(G3,Rates!B3:B7,0))
If you don't mean that, then upload a sample workbook of what you want.
I'm at the hospital from lunch, but can look before then.
MatthewR
I'll go through what you've suggested so far and see if that's what we are after, I'm waiting for the book to be issued but will fire you a pm as soon as we are in the correct position for it to discuss further if that's ok?
Yeah, no probs.
Always happy to help with this thing, gets my brain back active ready for returning to work.
After reading your post back, I dont think it is what you want.
  172 Cup
Save starting a new thread! I have a relatively simple bit of data 'presentation' that is causing me a big headache!
I would like to take the data from a single row and display it across a multiple row.....E.g. going from a 1x9 array to 3x3.
So created a tab and formatted the cells to look nice, then used a simple =Data!A2 etc to pull the data across. Works perfectly for the first line!
Then when copying/dragging down the 'formula' it is skipping rows....as I have made 3 rows, so it goes A2, A5,A8 etc etc.
Is there a way to force excel to copy the data sequentially?
There is circa 200 lines of data so don't fancy having to manually change the cell reference in 1400 cells (7 data points per row)!!
Screenshot of what is happening:
Should be =Data!A3!
Thanks!
