Excessive Crunching :0(
Guys I need your expertise info…
Every time I put the Willy in reverse, it crunches horribly. It started off doing it now and then, but it happens all the time now.:(
Is this an early sign that my clutch is on the way out? :confused:
I’m just a bit worried, cos I don’t want an f’d gearbox, as I’ve never had crunching problems like this before.
Ive tried differant techniques like puttin it in first before reversing and leaving the clutch depressed for a few seconds before reverseing, but nothing seems to work.
Help me please peeps!!!
Ian
I think they just do it sometimes mate. I had a new clutch and it does it still. Just make sure you push the pedal down as far as it will go. make sure the mats not under it either hehe.
Best thing to do is if you are just say reversing off the drive or whatever is to put it in reverse before you start the engine. thats what i usually do.
or just wait a second for the box to stop spinning.
Caused by you trying to select reverse to quick, stretched cable or dragging/warped plate.
I put it in reverse slowly, but it starts to crunch again,
so i have to leave it for a few minutes before itll go in without screamin its head off. Are u lot still sayin this is normal?
