Exhaust bracket
Hi does anyone know the part number or where I can get the rear exhaust mount that is bolted directly to the underside of the car? Basically the rear exhaust hanger attaches to this piece of metal. My car is a Clio 182 but I guess it's the same bracket you get on other clios. I've attached a small photo too. It's the bracket at the top part of the photo
Hi, I found out the part number is 8200324912
Any ideas where I can buy this part from online (don't fancy going to my local Renault dealer). thanks
Probably specific to the 182, as it's the only model which has the centre-exit exhaust. Chances are if you want it new, Renault will be the only place to go, very specific and probably not needed very often.
That, or get someone to make you one from some steel sheet.
  330i. E30 Touring.
Find someone breaking a 182. They'll be chucking that away.
Yep, or make something. Doesn't need to be pretty under there.
Thanks very much guys. I'm not confident making a bracket myself (yes I'm that rubbish:) so it looks like that link that flebay added should be somewhere to source it from. Unless anyone is breaking a 182 of course - let me know if so. At the moment my exhaust is being held up at the back with cable ties and wire :-0 as you can imagine it doesn't work too well!
Or if anyone knows someone that can make one from steel sheet? At £15 new though I might as well go with that as I probably won't find cheaper
